The Live plugin does not work in 0.5.1, the following patch fixes this (by using log_link_visit_action.idaction_url instead of log_link_visit_action.idaction (which does not exist))
I just updated to 0.5 and had the same problem, this fix appears to work. Thanks for sharing style_emoticons/<#EMO_DIR#>/smile.gif
thx thats works
How are you able to apply that diff file ?
Couldn’t you not just attach an already modified file ?
Sorry if i’m been a bit of a burden (or something).
Thanks blueyed.
I had the same problem with the liveOverView-Plugin.
I also replaced the “idaction” with “idaction_url” a few times.
It seems i did it right, the plugin works fine now.
Here is my edited LiveOverView-API-file. Just replace it with the existing.
All without guarantee! Make a backup before!
[attachment=251:API.php]
For me, that file produce a bigger bug.
Sorry.
