Parse Error on entering Settings
I just downloaded and installed piwik - everything went fine so far.
After logging in as superuser the backend shows up, but after clicking settings the following error comes up:
Parse error: syntax error, unexpected '}' in /is/htdocs/wpxxxx_JEZTWTUZR/piwik/plugins/ExampleUI/ExampleUI.php on line 61
Requirements are met. Any idea?
thanx
Reupload that file. Line 61 doesn’t have a ‘}’.
thank you for the quick reply. I reuploaded the whole piwik-installation-directory, deleted the DB and config. Still the same error.
On the Widgets-Page is a link to the Users Management section - clicking on it brings up a similar error:
Parse error: syntax error, unexpected '}' in /is/htdocs/wpxxxx_JEZTWTUZR/piwik/core/Period/Week.php on line 62
looks like my ftp-proggy is messing up the uploads! the file on the server has a “}”. weird.
I’ll get back to the forum if I can’t fix it.
Thanks for the clue style_emoticons/<#EMO_DIR#>/smile.gif
