Outlinks and download not working in GWT
#1
Hi all,
I am working on a GWT project and am asked to use Piwik for analytics. Having used both the default Javascript tracking code and the Gwt wrapper plugin I am still unable to track outlinks and downloads inside the GWT environment.
The login page is outside of the GWT context and works perfectly on outlinks so my Piwik server should be configured correctly. Goals and page views also work correctly in GWT.
Does anyone experience the same difficulties and/or have a solution?
Thanks in advance.
#2
Hi Tikwat,
I am looking for a solution to use piwik with gwt. The gwt wrapper plugin is not available for download any more. Can you please share the library and it’s source code? Or have you found another alternative to integrate piwik into gwt?
Thanks.
