Opt-Out Iframe with Update Info
Hi there,
today I saw the update page in my Opt-Out iframe. I believe this is not a feature :wink:
Best,
mickna
Can you try accessing your Matomo instance?
This means that Matomo is in Maintaince mode and disabled because you installed the Update, but didn’t yet run the database upgrades that are required after the upgrade.
Hi Lukas,
yes I can and I did all required steps. The point is: I did not change anything. A few days ago all was fine. But today I saw in the iFrame this update information.
But if this is not the “normal” behavior all is fine.
Thank you
