sorry guys I’ve a problem. i paste a simple image that can help you to understand me and find out the problem…
where can i find error log?
Hi @enzoibanez
It seems your MySQL server cannot be reached some times…
→ Mysql Server has gone away
Have a look at these different solutions:
I’ve write to my host service and it answer me like that:
The MYSQL server is configured with a wait_timeout of 180. This means that an idle connection will be closed by the MYSQL server after 180 seconds, and this action generates the reported error message.
MYSQL requires setting a value for this setting because the idle time cannot be infinite, and applications need to reconnect when disconnected from MYSQL.
In a shared hosting environment, this setting is also necessary because the number of connections to MYSQL is a limited resource shared by all the websites configured on the server instance.
If a specific application requires a longer idle time, you can set the session variable as follows:
SET WAIT_TIMEOUT=XXX;
Additionally, the CPanel service order [1] requires that queries do not last longer than 15 seconds:
2.2.4 - Server and Platform Resources
• Execute queries on the database that do not exceed 15 seconds.
Is this conversation helpful so far?
Hi @enzoibanez
I don’t know, as in Matomo example 28800
is set then 8 hours!
Did you try also to play with other parameters ?
Also, I imagine probably reports are built on the fly… That will consume huge resources, and because of the number of reports to be displayed, these resources are consumed high… in parallel !
Did you configure the data archiving by CRON instead of by browser?
Hi @enzoibanez
Very strange, the problem occurs before the 15 seconds timeout…
Is the server overloaded?
You did not reply to:
CRON can be set up and browser archiving also still enabled!
Does the CRON works sometimes ?
How many websites / visits / actions / segments do you track / use?
