Today I’ve upgraded my Piwik from 2.2.2 to 2.3.0 using “Update Automatically” method. The upgrade process
was successful, but something has been broken, because I couldn’t see any data. Please take a look at the attachment
with a screenshot. There are PHP syntax error and the missing files.
Can you have any idea what a reason of the issue could be?
Best regards,
Pawel
PS. I’ve downgraded my Piwik to 2.2.2, because I need a well working production server.
Yes, I use Apache server for my Piwik. Do you think that version 2.3.0 has some Apache related errors? I’ve been using Piwik for about 2 years and done a lot of upgrades, but I don’t remember such issues.
Is it safe to upgrade Piwik directly from 2.2.2 to 2.4.0? Or should I upgrade to 2.3.0 and then to 2.4.0?
I’ve got the same problem after upgrading to piwik 2.3. My system is a debian wheezy with apache 2.2.22-13+deb7u1. When I upgrade to piwik-2.4.0-b3 the problem persists with no errors in the apache-log, but an useable interface (logout link not clickable for example).
After little more trial’n’error I found a solution:
backup your config.ini.php
remove complete piwik folder
get latest.zip-piwik (version 2.3) and unpack it
place your backed up config.ini.php into the config folder
navigate to piwik as admin and you’ll maybe see some outdated plugins, which you have to reinstall over the marketplace …
It seems that I have too old version of PHP in order to install Composer… Well, it’s probably a good reason to upgrade my machine finally
# php composer.phar install
Loading composer repositories with package information
Installing dependencies (including require-dev) from lock file
Warning: The lock file is not up to date with the latest changes in composer.json. You may be getting outdated dependencies. Run update to update them.
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Installation request for symfony/console v2.4.4 -> satisfiable by symfony/console[v2.4.4].
- symfony/console v2.4.4 requires php >=5.3.3 -> no matching package found.
Problem 2
- Installation request for phpunit/php-code-coverage 2.0.6 -> satisfiable by phpunit/php-code-coverage[2.0.6].
- phpunit/php-code-coverage 2.0.6 requires php >=5.3.3 -> no matching package found.
Problem 3
- Installation request for phpunit/php-file-iterator 1.3.4 -> satisfiable by phpunit/php-file-iterator[1.3.4].
- phpunit/php-file-iterator 1.3.4 requires php >=5.3.3 -> no matching package found.
Problem 4
- Installation request for phpunit/php-text-template 1.2.0 -> satisfiable by phpunit/php-text-template[1.2.0].
- phpunit/php-text-template 1.2.0 requires php >=5.3.3 -> no matching package found.
Problem 5
- Installation request for phpunit/php-timer 1.0.5 -> satisfiable by phpunit/php-timer[1.0.5].
- phpunit/php-timer 1.0.5 requires php >=5.3.3 -> no matching package found.
Problem 6
- Installation request for phpunit/php-token-stream 1.2.2 -> satisfiable by phpunit/php-token-stream[1.2.2].
- phpunit/php-token-stream 1.2.2 requires php >=5.3.3 -> no matching package found.
Problem 7
- Installation request for phpunit/phpunit 4.1.0 -> satisfiable by phpunit/phpunit[4.1.0].
- phpunit/phpunit 4.1.0 requires php >=5.3.3 -> no matching package found.
Problem 8
- Installation request for phpunit/phpunit-mock-objects 2.1.0 -> satisfiable by phpunit/phpunit-mock-objects[2.1.0].
- phpunit/phpunit-mock-objects 2.1.0 requires php >=5.3.3 -> no matching package found.
Problem 9
- Installation request for sebastian/comparator 1.0.0 -> satisfiable by sebastian/comparator[1.0.0].
- sebastian/comparator 1.0.0 requires php >=5.3.3 -> no matching package found.
Problem 10
- Installation request for sebastian/diff 1.1.0 -> satisfiable by sebastian/diff[1.1.0].
- sebastian/diff 1.1.0 requires php >=5.3.3 -> no matching package found.
Problem 11
- Installation request for sebastian/environment 1.0.0 -> satisfiable by sebastian/environment[1.0.0].
- sebastian/environment 1.0.0 requires php >=5.3.3 -> no matching package found.
Problem 12
- Installation request for sebastian/exporter 1.0.1 -> satisfiable by sebastian/exporter[1.0.1].
- sebastian/exporter 1.0.1 requires php >=5.3.3 -> no matching package found.
Problem 13
- Installation request for symfony/yaml v2.4.4 -> satisfiable by symfony/yaml[v2.4.4].
- symfony/yaml v2.4.4 requires php >=5.3.3 -> no matching package found.
Potential causes:
- A typo in the package name
- The package is not available in a stable-enough version according to your minimum-stability setting
see <https://groups.google.com/d/topic/composer-dev/_g3ASeIFlrc/discussion> for more details.
Read <http://getcomposer.org/doc/articles/troubleshooting.md> for further common problems.
