Not track links containing a specific word
I have been using matomo for a short time, and I would like to know if there is a method (by Javascript) to exclude specific urls from tracking, for example:
exclude URLs that contain the word “test”.
thank you,
Any news regarding your question above?
I am interested as well with URL containing word “preview=”
It’s possible with JavaScript and a workflow.
First: remove _paq.push(['enableLinkTracking']); from your JavaScript tracking code. Yet, no link will be track by default.
Second: Put a onclick="matomolinktrack(this);" to all your links.
Create a function (put it in the HTML head above the matomo script):
<script>
// ↓↓↓ for Bertrand Marchand. case sensitive
function matomolinktrack(element_a) {
  var a_href = element_a.href;
  var url = new URL(a_href);
  var url_href = url.href;
  var url_params = url.searchParams;
  if (url_href.includes("test") === false) {
    _paq.push(['trackLink', url, 'link']);
</script>
<script>
// ↓↓↓ for ehquionest38. case sensitive
  if (url_params["preview"] === undefined) {
</script>
untested.
I use this in a similar way.
Edit:
Whit this code append the onclick function to all links.
Put it on the end of the HTML body.
<script>
var element_a_array = document.getElementsByTagName('a');
for (var i = 0; i < element_a_array.length; i++) {
	element_a_array[i].addEventListener('click', function(){matomolinktrack(this);});
</script>
Thank you for your help, but I don’t know where/how to set your script…
Another example, today I edit a new post on Wordpress and I can see that the following URL (https://www.xxxxxx.com/?p=30858 has been counted many times in the stats. How to prevent that?
Thanks
The following help page provides an example of how you can include a small ‘if’ statement in your tracking code to exclude a certain directory or page from being tracked - https://matomo.org/faq/how-to/faq_89/
This is added just before the ‘trackPageView’:
_paq.push(['trackPageView']);
You can slightly modify this to suit your needs, for example to exclude pages that contain p= in the URL:
if (!window.location.search.includes('p=')) {
To exclude URLs containing p= and a URL with the phrase ‘test’:
if (!window.location.search.includes('p=') && window.location.pathname.indexOf('test') === -1) {
OK, sorry, a misunderstanding (Link / URL). Follow @goochj03 solution.
I am using “Matomo Connect” plugin for Wordpress. So I modified manualy the code for this one:
<!-- Matomo -->
<script>
  (function() {
    var u="https://xxxxxxxx.com/";
    g.async=true; g.src=u+'piwik.js'; s.parentNode.insertBefore(g,s);
</script>
<!-- End Matomo Code -->
It should be correct right?
Thank you again !
Using the Matomo Connect plugin is fine but you would only want to amend your existing trackPageView rather than having this added twice. For example:
<!-- Matomo -->
<script>
  (function() {
</script>
Professional (for URL query excluding).
A good base also for other solutions.
<!-- Matomo -->
<script>
// Start matomo custom
function set_trackPageView() {
  var dontTrack = "p";
  var url = new URL(window.location.href);
  if (url_params[dontTrack] === undefined) {
// End matomo custom
  set_trackPageView(); // custom function above
  (function() {
</script>
