(I’ve also tried “localhost” the FQDN of the host, the IP, etc.)
I see in the forums a similar error with an older version of piwik and an inability to write the configuration file, permissions are correct for this to be written by the httpd uid.
Additionally, if I manually create config.ini.php with appropriate values, I get the following error:
The mysql driver is not currently installed
Backtrace:
Backtrace:
[quote=draingirl @ Nov 23 2009, 07:50 PM]I had the same problem.
Contact your hoster and ask him if Pdo_mysql is installed.
This could be the problem.[/quote]
Yes, the " extension=pdo_mysql.so " object needed to be installed before the db could be created.
Shouldn’t this extension be in the pre-flight checks?
