on 2 Websites, both running Woltlab Burning Board, one Vserver and one root, I’ve installed piwik, which is running fine.
Even after setting a cronjob (on the vserver via a webgui from the provider all-inkl , on the root via crontab -e , as described in the manual) for auto-archiving and disabling the reports via Browser, i get “not data” in piwik.
On the root server, I had a look a the syslog and found :
Apr 9 09:40:01 snake /USR/SBIN/CRON[9185]: (CRON) error (grandchild #9186 failed with exit status 127)
Apr 9 09:40:01 snake /USR/SBIN/CRON[9185]: (CRON) info (No MTA installed, discarding output)
I’ve set the time for the cronjob to 40 * * * * for testing.
As google told me, exit status 127 means “command not found”. But as well, runnning the command via shell, everything works fine. I tried a several versions of the command in crontab, but without success. And yes, I did chmod 755 for the archive.sh
Thanks in advance for help…
