I am setting up Matomo 4.5 on a new server with nginx.
In the System Check I am getting the error that the URLs are accessible from the internet.
I don’t understand why. When I manually request the URLs I get a 403 (forbidden)
In the FAQ the recommended solution for nginx is:
We recommend setting the same configuration as in our Nginx repository or directly using this repository to configure your Matomo installation.
This is exactly what I am doing and the config contains:
## disable all access to the following directories
location ~ ^/(config|tmp|core|lang) {
deny all;
return 403; # replace with 404 to not show these directories exist
So it looks to me as if the configuration is correct but I am still getting this error.
