I just installed Piwik on a new MS Server 2008 install and I get the following error.
"There was a problem installing the plugin ExampleFeedburner: SQLSTATE[42000]: Syntax error or access violation: 1142 ALTER command denied to user ‘root’@‘192.168.1.10’ for table ‘piwik_site’ If this plugin has already been installed, and if you want to hide this message, you must add the following line under the [PluginsInstalled] entry in your config/config.ini.php file: PluginsInstalled[] = ExampleFeedburnerThere was a problem installing the plugin Provider: SQLSTATE[42000]: Syntax error or access violation: 1142 ALTER command denied to user ‘root’@‘192.168.1.10’ for table ‘piwik_log_visit’ If this plugin has already been installed, and if you want to hide this message, you must add the following line under the [PluginsInstalled] entry in your config/config.ini.php file: PluginsInstalled[] = Provider "
The root was not enabled originally, but I added that and got the install to complete. Where is this ExampleFeedburner available from?
