Need help making a template global
I have recently done a template but i need to use it for several plugins, but i dont want to add the template to each for it to, work so i was wondering if theres anyway to make it global and how?.
Thanks
what does the new template do exactly? Maybe you will need a new hook to provide the functionality across existing datatables ?
It almost the same evolutionGraph template but i added a combobox for selection of a parameter, ill be using it for several plugins in the future so i wanted to know if I could make it a global template and how? maybe, can it also be called like a js file including the path in the plugin I want to use it?
I just want to avoid reusing code i already have in another plugin if i can. tnx.
