Based on iis6.0+fastcgi+php +mysql 5.1 (php-5.2.11-nts-Win32), the systemCheck detected environme problems during the piwik 0.4.5 installation . According the phpinfo(mac.ntu.edu.cn/aa.php),the mysqli/pdo/pdo_mysql works well,but in the "systemcheck",the "PDO extension" is ok,then the RED (mac.ntu.edu.cn/piwik/index.php?action=systemCheck) I found
"Piwik requires either the mysqli extension or both the PDO and pdo_mysql extensions.
On a Windows server you can add the following lines to your php.ini:
extension=php_mysqli.dll
extension=php_pdo.dll
extension=php_pdo_mysql.dll
More information on: PHP PDO and MYSQLI. "
I found this code from the forum :
<?php
$extensions = @get_loaded_extensions();
if (in_array('mysqli', $extensions) && function_exists('mysqli_set_charset')) {
echo "MySQLi is supported\n";
if (in_array('PDO', $extensions) && in_array('pdo_mysql', $extensions)) {
echo "PDO MySQL is supported\n";
the result is still ok(mac.ntu.edu.cn/aa.php) the next is using PDO to get "test data". Where I am wrong, thank you for any help!
The version of my php on my home server is 5.2.11 and those extensions are already enabled, but piwik don’t see that, I also have a joomla site running and there is no problem.
Could you please tell me how you got it to work because I can not find a solution.
9. Installation on Windows server is broken
Comment out (or remove) the line containing escapeshellcmd from core/Piwik.php
CODE
// $sDir = escapeshellcmd($sDir);
I just follow the "9/Installation on Windows server is broken"
Comment out the code " $sDir = escapeshellcmd($sDir);"
and then it works.
My situation is the pdo/pdo_mysql works well, the problem is something differences between the windows and linux,and I didn’t google to find the truth…
how your system appeared from the code “301 Moved Permanently”
