I’ve got a clean version of piwik running and I’ve noticed that, as expected the first time I hit a page which calls the tracking code, I can see my visit registered in the visitor log.
If my page then sends an event, then whilst I see the event registered, I also notice that a new visitor profile ID is issued.
Is it possible therefore that this will be registered as two visits?
We’ve got 1-to-many web servers behind an AWS Elastic Load Balancer which solely collects data. There’s a separate standalone instance upon which we run the UI and which also runs the archiving cron
Because requests are all served through the ELB and it’s highly likely that a user’s action will seldom be recorded by the same web server behind the load balancer, I know that might cause session issues so I’ve enabled:
This one is not recommended. You should enable this setting only if you track an intranet site (many devices/workstations with same IP and configuration - browser fingerprint). See this one: http://piwik.org/faq/how-to/#faq_19
Currently, it’s possible to create many visits if cookies support is disabled in the browser.
Should I set that to zero or remove the entry altogether? If I do, will Piwik behave properly given that there is no guarantee that the piwik web server which first serves a user, will be the one that serves subsequent piwik requests? Such is the challenge of a load-balanced environment
