This is done deliberately, if you look at the piwik_log_conversion table there is a primary index of idvisit,idgoal.
Because of this for each visit that a user makes to your site there can only be one conversion for each goal that you have setup.
[quote=jstock @ Aug 25 2010, 02:12 PM]This is done deliberately, if you look at the piwik_log_conversion table there is a primary index of idvisit,idgoal.
Because of this for each visit that a user makes to your site there can only be one conversion for each goal that you have setup.[/quote]
Thanks, I guessed as much.
However, I would argue that if I tell Piwik (with trackGoal) that it’s a Goal, then it IS a Goal!!
I wanted the goals to be tracked as many times as they happened for each visitor.
I therefore added the server_time field to the primary key of the piwik_log_conversion table.
Now goal conversions are alway tracked on my system
Ok, but I’d like to repeat the main issue: that if I use trackGoal to specify a Goal, it IS a Goal and Piwik shouldn’t take it upon itself to decide that it isn’t !!
