Multi Tenant and plugin prizing
Hi there!
I have a tenant question. If we plan a multi tenant Matomo setup, does the prices change for Plugins? Or is it the case, if I buy the most expensive plugin tear, that then it is ok for a multi tenant setup?
Thank You!
Hi @Grienauer ,
When you purchase a license for premium plugins, you can use your premium plugins on up to two instances: one production instance, and up to one testing or staging instance.
Every instance in the multi tenant environment will be considered as separate Matomo instance, so you may need to consider separate license for each tenant.
thx. can you guide me to some official document of that please.
maybe I have another understanding, what tenant means.
Over at “subscription-guide” page (sadly I can not add a link here as the forum is prohibiting this (at least for my account) :stuck_out_tongue:
All the subscription types allow you to do the following:
  • Tracking of unlimited actions and visitors
  • Tracking & usage on unlimited websites and apps
  • Usage on unlimited servers within one Matomo instance
If I have one matomo instance, Which runs in a “cluster”, then this should be ok I guess?!
thx in advance!
Hi @Grienauer ,
Please review to understand the context of Matomo about multi-tenancy https://developer.matomo.org/guides/multi-tenants. If you mean multi-server environment (cluster) and one instance of Matomo is hosted across, then it is considered as one server.
Hi @karthik a followup on staging instances, how do you distuinguish whether an instance is production or staging? So that I can make sure my license key isnt cancelled. Also Is there any way to migrate changes done on staging instance to production instance easily??
@innocraft can you answer the above question from me?
Hello @vverma21 We don’t distuinguish if the instance is production or staging. We only use that statement as an example. To clarify things better, if you purchase a subscription you can use it on up to 2 Matomo instance. For example matomotest1.yourdomain.com and matomotest2.yourdomain.com. If your setup another Matomo instance like matomotest3.yourdomain.com, the license key will not work because on this last Matomo instance.
For your other question, can you please clarify on what you are planning to migrate?
Hi @Emerson_N, I thank you for your responsiveness.
Any changes we do on our staging instance, could be Tag manager changes, funnels, heatmaps, dashboards, custom dimensions, anything and everything, we would like to migrate to production like a deployment
Matomo do not have a single click feature that lets you automatically migrate all configuration changes (Tag Manager, funnels, heatmaps, dashboards, custom dimensions, etc.) from one instance to another. While it is technically possible to transfer certain data or configurations by copying database tables or using export/import features.
