Hello.
I need to migrate plugins from one Matomo installation to another. I head that there’s a limit how many times a plugin can be activated.
We will completely disable and delete our first Matomo installation and move to the second one so I have few questions:
- Is using “Remove License Key” button enough to make the key free to use on another Matomo installation?
- Can I use the same key on second Matomo after removing if from the first one?
- Are there limits how many times we can remove keys and activate them on other installations?
Thanks
