Recently, after moving the domain which had Piwik running to HostGator, none of the sites were able to send stats to Piwik. So I moved the Piwik installation (copied folder and exported/imported the DB) to a location where I knew it worked before. Sites are now able to send the stats again but a couple of links send me to a 404 page after the move? Are there any other settings or paths that need to be changed in the DB or config files which might fix this?
The links which no longer work are the “Settings” page and the link to upgrade to 1.6.
