First of all I want to say thanks a lot to the Piwik team for the software – I really appreciate not having to use google analytics.
But - since I upgraded to 1.4, the “referrers” widget and the “keywords” widget, along with best search engines, are blank for all days since the upgrade. Actually they say that “there is no data for this report”. And on the visitor log, all visitors are called “direct entry” and I’m pretty sure that’s not the case.
I don’t see an obvious problem. A 301/302 redirect should preserve the original Referer header (unlike meta refresh, or changing the window.location object in JavaScript).
This is happening to me also. I tried to post a support ticket which wasn’t really answered. I got my bum smacked for posting another ticket and I was instructed to come here. It seems this thread has not been resolved. There are no iframes on my site and the javascript tracking code is in the right place. Although normal direct tracking seems to be working. Keyword and search engine results are working on tracewatch stats and awstats, So the rewrites can’t be the problem. The re-writes I have simply add www. and remove the trailing .php from the end of the url. I’m using htaccess to rewrite:
