Missing "Allow goal to be triggered more than once per Visit"
The option to allow for multiple goals per visit is not there. Not when i make new goals or edit old ones.
Not even when I put the exact same options shown here.
https://matomo.org/docs/tracking-goals-web-analytics/#examples-of-useful-goals
Here is what I am using. It is a nearly brand new install.
Thanks for the report. We have fixed this issue in the latest beta 3.12.0, you can update following instructions in: I would like to test early beta and RC releases, how do I enable automatic updates to use these development versions? FAQ - Analytics Platform - Matomo
May I assume that is the same issue with Matomos latest release:
I have recently added new goals.
These goals are initiated via “_paq.push ([‘trackGoal’, 9]);” and sent as “https://matomo.tld/piwik.php?idgoal=9&idsite=23&rec=1&…” to the Matomo instance.
Matomo records the goal only once per visit - no matter what are the settings.
The Goals I created around one year ago are not affected. These are recorded several times per visit.
Or is this another problem?
Hi Pak,
To have the issue fixed, please upgrade to Matomo 3.12.0 beta as explained: I would like to test early beta and RC releases, how do I enable automatic updates to use these development versions? FAQ - Analytics Platform - Matomo
After upgrade, the goals should be tracked correctly? or maybe you need to re-save them with the right setting. Thanks,
