Migration Problem - time gap in imported data
Hello, I’m having a bit of a problem importing ‘old’ data. I’ve upgraded an old installation from 4.0.4 to 5.14 and wanted to transfer it to my now centralised installation using `migrate`. The command line runs through without any issues, but in the destination Matomo, the data between 2018 and 2025 is missing; everything else (2007–2017, 2025–present) is present. All the data is also visible in the source system. Deleting it and re-importing it didn’t help. There were no error messages.
Does anyone have any ideas?
I would first check whether the source and destination Matomo installations are using the same database structure/version. The Migration plugin documentation specifically recommends having both instances on the same Matomo version, or at least the same DB structure.
Since the missing period is a specific range while the earlier and newer data are present, I’d also check whether the raw visit data actually made it into the destination database, rather than assuming it’s only an archiving issue.
If the raw data is there but the reports are missing, try reprocessing the affected periods with core:archive. Matomo recommends reprocessing when only particular days, weeks, or months show no data.
I would also run ./console diagnostics:run and ./console core:update on the destination to rule out an incomplete upgrade or database-schema issue.
If it still happens, I’d compare a few dates from 2018 2025 directly in the source and destination log_visit/archive tables. That should help determine whether the migration skipped the raw data or whether Matomo simply is not displaying/archiving it correctly.
Thank you very much, that worked!
Did this way
john@doe:/var/www/matomo# php ./console core:invalidate-report-data --dates=2017-01-01,2025-01-31 --sites=22
(maybe not necessary)
and
john@doe:/var/www/matomo# php ./console core:archive --force-idsites=22 --force-date-range=2017-01-01,2025-01-31 --url=https://statistics.domain.tld/
All data is displayed again. :grinning_face:
Good to hear that fixed it. The result also makes sense since Matomo stores the reports in archived data, so reprocessing the affected range can bring the missing historical reports back when the underlying log data is still available.
Nice that you found the exact date range and site ID instead of having to rebuild everything.
