Fatal error: 1 total errors during this script execution, please investigate and try and fix these errors. First error was: Got invalid response from API request: http://********.com/index.php?module=API&method=VisitsSummary.getVisits&idSite=7&period=day&date=last52&format=php&token_auth=**************************&trigger=archivephp. Response was '<br />
<b>Fatal error</b>: Maximum execution time of 30 seconds exceeded in <b>/opt/piwik/core/DataTable/Filter/Sort.php</b> on line <b>64</b><br />' in /opt/piwik/misc/cron/archive.php on line 179
This website has a TON of traffic so a random theory that maybe it is being hit so much it cannot grab all the data? Is there a way we can extend the execution time??? Or some other trick we can do to the DB to accept more connections or something???
Missed that portion…That solves the error message of “30 Seconds” but we are still getting the error…
Fatal error: 1 total errors during this script execution, please investigate and try and fix these errors. First error was: Got invalid response from API request: http://**********************/index.php?module=API&method=VisitsSummary.getVisits&idSite=7&period=day&date=last52&format=php&token_auth=***********&trigger=archivephp. Response was 'curl_exec: Empty reply from server' in /opt/piwik/misc/cron/archive.php on line 179
If I place the link into a web browser it returns the results however. The link example that is given in the output is this:
I was able to solve the issue. If a website fails during the archive.php script, especially one receiving millions of hits per day, it is extremely difficult for it to pull all the data it has been missing, thus a cycle which it will never actually grab the data. I was able to do the following to get it to work and continue to work. If I lower the settings even by “50” it stops working.
I set: max_execution_time=600
max_input_time=120
memory_limit=increased significantly from where we would have liked it to be
MaxClients=500
Note* If I set any of these values any less…the script fails to run the site
Piwik is an amazing software but if you are running on a large installation with millions of hits it will need a lot of tweaking. I do want to thank you guys for giving us the archive.php script. Night and day difference. Great work!
