I am trying to adjust the max_execution_time from 30 to 60 seconds. I can see the change I made in “config.ini.php” file under Diagnostics/Config file in Matomo, however the max_execution time is still show as 30 sec in the error logs.
My question is; Is there another config file that needs to be updated and/or could a plugin need to be configured?
Not running apache2 or php-fpm. phpinfo() shows /etc/php.ini is being read.
The Apache server has been restarted multiple times, max_execution_time has been changed to 60 and 0 with no effect. I can’t find any other config setting controlling this. However, when we start loading some of the data in Matomo, this is generated in the ssl_error_log;
PHP Fatal error: Maximum execution time of 30 seconds exceeded
