We have installed Matomo for WordPress in our site, but it doesn’t work.
We have the following problem: “Your PHP cli version is not compatible with the Matomo requirements. Please upgrade your PHP cli version, otherwise, you might have some archiving errors.Your PHP cli does not load the MySQLi extension. You might have archiving problems in Matomo but also others problems in your WordPress cron tasks. You should enable this extension.”
We have updated the php version and we have also verified the correct enabling of the MySQLi extension.
Unfortunately the problem persists.
How can we fix?
