Matomo v5.5.1 : Warning - Implicit conversion from float to int loses precision
After upgrade from v5.5.0 to v5.5.1
In CLI mode (e.g. running core:update) and in the backend.
WARNING core/Menu/MenuAbstract.php(108): Deprecated - Implicit conversion from float 40.5 to int loses precision
Not critical but someone should maybe take a look (e.g. use an explicit conversion).
P.S.
PHP v8.2
MariaDB 10.11.14
Update:
The cause is the change of the method signature of MenuAbstrart→addItem() in this recent commit:
Git Hub: /matomo-org/matomo/pull/23648 (sorry can’t post direct link)
And, at least in our case, the menu item with a float order value of 40.5 comes from the AdvertisingConversionExport plugin:
plugins/AdvertisingConversionExport/Menu.php line #33, in call to $menu->addMeasurableItem().
As AdvertisingConversionExport comes also from the core team, there needs to be some coordination here.
Either $order is allowed to be a float value in MenuAbstract or all plugins need to use an integer value when calling addItem()/addMeasurableItem().
having the same problem after updating
WARNING: /core/Menu/MenuAbstract.php(108): Deprecated - Implicit conversion from float 40.5 to int loses precision - Matomo 5.5.1 - Please report this message in the Matomo forums: (please do a search first as it might have been reported already) (Module: CorePluginsAdmin, Action: plugins, In CLI mode: false)
Hey guys, we are aware of this issue. There should be a new release of the AdvertisingConversionExport plugin soon, which will fix the issue.
Given that the menu class is higjly likely to be used by 3rd party plugins, changing the signature of a public method in a patch-level release of the core is, as Sir Humphrey would say, “courageous”.
