I have Matomo deployed in AWS ECS (matomo:4.15.1). It is connected to RDS MariaDB (mariadb:10.6).
Using the mysql CLI, when I run commands like SHOW PROCESSLIST; and SELECT * FROM INFORMATION_SCHEMA.INNODB_TRX order by trx_started limit 10; I see a lot of matomo queries. Some seem to be running for more than 2 days.
The container’s memory seems to be going up non-stop until it’s OOM killed. Database CPU utilization and connections are also very high. For example (sorry, can only post one image since I’m a new user):
Hi @doublethink
I think this depends on the number of actions you are tracking. What is the volume?
Peaks and holes seem to come from data archiving, as they are periodic on the month… I think the unique visitor processing is defined on the month, isn’t it?
Your volume is not high…
Maybe a great number of plugins or dimensions could impact negatively performances…? Do you also process data for any kind of time range?
Looking more precisely your graphs, I don’t understand you can use… 176% of CPU!
