Matomo doesn`t record events
Hi!
I set up several tags. They are fired, but don`t appear in visits log. What could be a reason for that?
Thanks!
Hello Julia,
we need more informations. Can you post a screenshot here from your tag-definition?
Regards
Udo
Hi there, I have the same problem. in debug mode my tags seem to fire - but they dont appear in visitors log or in events/content
what exactly should i screenshot to help you help me? :-))
thx in advance
Hi @Ruso ,
if your events are fired then it could be a problem with a misconfiguration of the variable “Matomo configuration”. Do you have configured the correct Matomo site-id?
You should check the Dev Tools of your browser, when the Tag Manager debug mode shows firing the event.
Is there a network request to your Matomo-server? Does the request contains the right Site-id? Or is there a JavaScript-error at the browser console?
Greetings Udo
Hi Udo,
sorry for the late reply. I found the solution - it was really a misconfiguration of the variable.
Thx a lot :slight_smile:
