I have implemented the basic code but I want to add some additional options and don’t know if this is the correct way of doing it.
I didn’t see anything with regards to having to enable / disable the tag manager for privacy purposes. I am assuming that it simply remains active.
<script>
var _mtm = window._mtm = window._mtm || [];
_mtm.push({'mtm.startTime': (new Date().getTime()), 'event': 'mtm.Start'});
(function() {
g.async=true; g.src='https://mydomain.net/piwik/js/container_fAREuJHL.js'; s.parentNode.insertBefore(g,s);
</script>
I am using this in Php through a CMS and using the cookie that is set if the user accepts or rejects below:
<script>
_paq.push(['setSecureCookie', true]);
_paq.push(['setVisitorCookieTimeout', '604800']);
_paq.push(['setDownloadExtensions', "jpg|pdf"]);
_paq.push(['trackPageView']);
(function() {
var u="//mydomain.net/piwik/";
</script>
and for the opt out:
<script>
_paq.push([function () {
_paq.push(['optUserOut']);
</script>
I look forward to your answers.
Thanks in advance.
