Hi Trying to set goal selecting [ Goal is triggered Manually option ].
I have added below code for tracking goal:
var _paq = _paq || [];
/* tracker methods like “setCustomDimension” should be called before “trackPageView” */
window.addEventListener(‘beforeinstallprompt’, function (e) {
console.log(‘in beforeinstallprompt’);
_paq.push([‘trackGoal’, 1]);
_paq.push([‘trackPageView’]);
… /* track code continues */
When I goto the goal to see report (after performing action) there is no conversion found.
Please suggest what value I need to add instead of “1” in _paq.push([‘trackGoal’, 1]); so I can see the goal tracking.
Or kindly suggest if there is another way to do so.
Thanks in advance.
