Manual device info on api
hi every body
i’m android/web developer and using piwik for track my app usage (piwik is amazing!)
you know device detection is not very accurate !
i have full access to device info on android app
:rotating_light: but problem is how can i use this data on piwik !?
my app send info&stats to app-server and app-server sends it to piwik using php-client.
:bulb: what could be helpful:
1- a plugin or some codes that can change device-detector to use uncommon format for UA !
ex: use jsonned data of device info instead UA !
2- some code that can create new or improve current UA of device
ex: a function that input device model & brand & android version and return standard UA string that device-detector parse it correctly.
3- any other suggestion !?
(sorry for text if its not good enough, English is not my mother tongue)
Hello @mghayour
We need your help to make device detection better. Please contribute on our project at: GitHub - matomo-org/device-detector: The Universal Device Detection library will parse any User Agent and detect the browser, operating system, device used (desktop, tablet, mobile, tv, cars, console, etc.), brand and model.
