I just replaced mysql with mariadb but I don’t think it matters in this case:
If I enable skip-name-resolve in my.cnf, Piwik throws a database connection error, saying that it can no longer access the database with user admin@127.0.0.1, so I disabled skip-name-resolve for now.
Piwik is on the same server as the database.
What do I need to do for Piwik to work with skip-name-resolve turned on?
You simply need to add a GRANT for your database user. You probably have a GRANT for admin@localhost but not for admin@127.0.0.1. You can check that doing this query as MySQL root:
SELECT User,Host from mysql.user;
You can add the grant with this other query (assuming your database is called “piwik”):
I think it’s because you are using 127.0.0.1 and the DNS can’t resolve that address. I would try either using the actual IP Address of the machine or creating a hostname and using a local DNS to resolve the hostname.
Thanks. I’d prefer the latter to avoid any external round trips. Assuming I can setup a local DNS to resolve the created hostname, where do I need to make the change so that Piwik uses it? I looked in the Piwik config file but don’t see anything obvious.
