LoginLdap problem LdapUsers.php
hello to all
I am finding this error
any ideas?
Matomo 3.8.1
LoginLdap 4.0.6
./console loginldap:synchronize-users
INFO [2019-02-28 14:44:42] 1387 LdapUsers::makeLdapClient: Using LDAP server xxx:389
WARNING [2019-02-28 14:44:42] 1387 xxxpiwik/plugins/LoginLdap/Ldap/Client.php(375): Warning - ldap_search(): Search: Bad search filter - Matomo 3.8.1 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
WARNING [2019-02-28 14:44:42] 1387 xxx/piwik/plugins/LoginLdap/Model/LdapUsers.php(312): Warning - Invalid argument supplied for foreach() - Matomo 3.8.1 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
Synchronized 0 users!
Error: error or warning logs detected, exit 1
I have the same problem, how did you solve it?
This looks like it could be related to the LDAP search filter or the way the LDAP users are being returned. Since the log shows a “Bad search filter” followed by an invalid argument warning, I’d double-check the LDAP configuration and filter syntax first. Hopefully someone can help identify the exact setting causing it.
Check your LDAP user filter first. “Bad search filter” usually means the configured LDAP filter has invalid syntax—especially parentheses or an incorrect attribute. Verify the LoginLdap user search/filter settings and base DN.
