Log deletion problem
I have a log deletion problem after importing 2 years worth of logs with import_logs.
The database purge runs with a limit
DELETE FROM piwik_log_link_visit_action WHERE idvisit < ‘6085418’ LIMIT 100000;
here is the appropriate line of code
core/PluginsFunctions/Sql.php: static public function deleteAllRows( $table, $where, $maxRowsPerQuery = 100000, $parameters = array() )
there doesn’t appear to be a way of configuring this limit but maybe I am wrong.
select count(*) from piwik_log_link_visit_action WHERE idvisit < ‘6085418’;
returns '159492548’
so at the rate of 100000 deletions per day this will never catch up, I am adding ~ 300000 lines per day
does anyone have an idea?
the code is:
do
			$rowsDeleted = self::query($sql, $parameters)->rowCount();
			$totalRowsDeleted += $rowsDeleted;
		} while ($rowsDeleted >= $maxRowsPerQuery)
so it should delete continuously until all are deleted?
ahh yes, I should have looked a little deeper sorry.
I think that my php process was being killed by fcgid or php before the SQL had a chance to finish removing records as the select was still showing 156 million after several days of attempted purges. I had extended the allowed runtime to several mintues but it obviously wasn’t sufficient.
I ran the SQL manually without the limit and everything is fine now. Hopefully it will run quickly enough from now on.
thanks
