I was looking for a config file that saves location provider to GeoIP2(php).
I have 20+ sites and need to update location provider on all with an automated deployment scripts. I could automate the downloading and deploying GeoLite2-City.mmdb file to misc folder but I still need to select and save from Geolocation settings manually.
Would really appreciate if you can help me finding the geolocation settings file.
Let me know if I am not clear or you need more details.
Thanks
