Load matomo on document ready
How can I load matomo on document ready?
I have to load the script when $.cookieAccepted() is true (I’ve checked its value and it’s true), but seems the matomo.php not reached.
Here is the code snippet:
$(document).ready(function () {
    if ($.cookieAccepted()) {
        var _paq = window._paq || [];
        _paq.push(['trackPageView']);
        (function() {
            var u="//analytics.myCompany.com/";
            _paq.push(['setSiteId', '3']);
            g.type='text/javascript'; g.async=true; g.defer=true; g.src=u+'matomo.js'; s.parentNode.insertBefore(g,s);
You code seems perfectly fine to me, can you send me the URL of your site via PM so I can take a look?
Ok, I can confirm that there is some problem.
If I run Matomo.getAsyncTracker().getTrackerUrl(); on your site I get an empty string instead of //analytics.myCompany.com/matomo.php, so there will be nothing tracked.
I currently have no idea why the tracker is not setup the way it should. If I set the tracker URL and the site id via devtools I’m able to track pageviews.
So if you know your job with JS, you might just workaround the problem with something like this
var mt = setInterval(function () {
    if (Matomo.initialized) {
        clearInterval(mt);
        Matomo.getAsyncTracker().setTrackerUrl('https://analytics.***.fr/matomo.php');
        Matomo.getAsyncTracker().setSiteId(1);
        Matomo.getAsyncTracker().enableLinkTracking();
        Matomo.getAsyncTracker().trackPageView();
}, 250);
Maybe @Lukas has an idea why the _paq pushing itself is not working.
Ok for instance I’ve modified my script like this:
        //_paq.push(['trackPageView']);
        //_paq.push(['enableLinkTracking']);
        (function() {
            var u="//analytics.mySite.com/";
            //_paq.push(['setTrackerUrl', u+'matomo.php']);
            //_paq.push(['setSiteId', '1']);
                clearInterval(mt);
                Matomo.getAsyncTracker().setTrackerUrl('https://analytics.mySite.com/matomo.php');
                Matomo.getAsyncTracker().setSiteId('1');
        }, 250);
Thanks for your investigation!
