LinkedIn conversion tag
So I’m trying to implement LinkedIn conversion tracking for the site and but the LinkedIn Insight tag doesn’t seem to have any field for adding the conversion ID? Also is this the LinkedIn Insight 2.0? How is this meant to even work?
Should I even be using the LinkedIn tag? If not can we remove all old outdated stuff from it?
Hi @Feldon
I saw this:
But I never used it!
Yeah, doubt it works. I had to use custom html and add the scripts manually instead.
