im struggling with this for weeks. Ive got my piwik installation on WiredTree 1024mb ram VPS.
there are ~1150 sites which all are very low traffic(10-20 visits each per day). I am able to see each particular site, but i really need to be able to see the All Websites tab and sort the sites by visitors count in various periods.
What ive done:
set up archiving hourly with a cronjob (takes like 5 minutes to archive)
set refreshing reports to 3600 seconds in piwik configuration
php memory limit 512mb
php script timeout 180seconds
when i click on all websites, it thinks for 10-20 seconds, and then stops and a blank page appears.
The patch should help indeed. You should run SVN and see google on how to apply a patch file.
Otherwise the easiest way to show a dashboard is to use the API VisitsSummary.get
If you pass idSite=all it will return for all websites…
