Hey there,
I wanted to made the new update, but there appears some issues. First I had a wrong PHP Version (Changed to 5.6), after that I get the info some tables was missing. I followed Updating from 2.16 to 3.0.0b1 fails: piwik_site_setting doesn't exist · Issue #10703 · matomo-org/piwik · GitHub to try to solve the issue myself, but now there is a new issue.
Kritischer Fehler während der Aktualisierung:
SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘plugin_name’ in ‘where clause’
This seems to be in connection with:
CREATE TABLE piwik_site_setting (
idsite INTEGER(10) UNSIGNED NOT NULL,
plugin_name
VARCHAR(60) NOT NULL,
setting_name
VARCHAR(255) NOT NULL,
setting_value
LONGTEXT NOT NULL,
user_login
VARCHAR(100) NOT NULL DEFAULT ‘’,
INDEX(idsite, plugin_name)
) ENGINE=$engine DEFAULT CHARSET=utf8
Of corse I use the Prefix. Are there any ideas what I could make?
Thanks a lot!
