All,
I’ve noticed that when making a request to the VisitsSummary.getUniqueVisitors API with the year period, the result is always 0.
For example, if I go to:
/index.php?module=API&method=VisitsSummary.getUniqueVisitors&idSite=1&period=day&date=today&format=JSON&token_auth=xxx
the result is:
{value: 1}
but if I go to:
/index.php?module=API&method=VisitsSummary.getUniqueVisitors&idSite=1&period=year&date=today&format=JSON&token_auth=xxx
the result is:
{value: 0}
Is this a known issue or am I otherwise (hopefully) missing something? Does anyone else see this behavior?
(The version is 1.1.1)
vipsoft
(vipsoft)
2
The number of uniques in a year is not computed for performance reasons.
endway
3
I’m having the following issue with the same widget.
index.php?module=API&format=php&token_auth=anonymous&widget=1&idSite=2&method=VisitFrequency.getUniqueVisitors&period=range&date=2011-08-01%2C2011-09-20
result: 0
/index.php?module=API&format=php&token_auth=anonymous&widget=1&idSite=2&method=VisitFrequency.getUniqueVisitors&period=month&date=today
result:7
Any suggestions?
matthieu
(Matthieu Aubry)
4
matthieu
(Matthieu Aubry)
5
matthieu
(Matthieu Aubry)
6
