Issue with Visitor Map using segmentation?
I’m not sure if this is a bug, but when I use
?segment=customVariablePageName1==ID;customVariablePageValue1==XXXX
the Visitor Map breaks, showing no data. However, if I just use
?segment=customVariablePageValue1==XXXX
it works as expected.
It’s an old version of Piwik (1.12.something)
Hi there,
This is a bug. We will fix it in next version 2.15.0 VisitorMap sometimes does not show data when segment parameter is used and URL encoded · Issue #8813 · matomo-org/piwik · GitHub
Thank @rogerk , I was about to post a new topic for the same issue. I am using Piwik 2.15. i also noticed the same bug on the demo version of Piwik : Piwik Forums - Tuesday, January 9, 2018 - Web Analytics Reports - Piwik
As a workaround, using only the value works for me since my values a unique.
