After update to v3.1.10 the plugin “ip2location” no longer works.
I’m getting following error:
[28-May-2019 05:52:34 UTC] PHP Fatal error: Uncaught Error: Class ‘IP2Location\Database’ not found in […]/plugins/IP2Location/LocationProvider/IP2Location.php:86
Stack trace: #0 […]/plugins/UserCountry/VisitorGeolocator.php(145): Piwik\Plugins\IP2Location\LocationProvider\IP2Location->getLocation(Array) #1 […]/plugins/UserCountry/VisitorGeolocator.php(115): Piwik\Plugins\UserCountry\VisitorGeolocator->getLocationObject(Object(Piwik\Plugins\IP2Location\LocationProvider\IP2Location), Array) #2 […]/plugins/UserCountry/Columns/Base.php(50): Piwik\Plugins\UserCountry\VisitorGeolocator->getLocation(Array, true) #3 […]/plugins/UserCountry/Columns/City.php(43): Piwik\Plugins\UserCountry\Columns\Base->getLocationDetail(Array, ‘city_name’) #4 […]/core/Tracker/Visit.php(460): Piwik\Plugins\UserCountry\Columns\City->onNewVisit(Object(Piwik\Tracker\Request), Object in […]/plugins/IP2Location/LocationProvider/IP2Location.php on line 86
When i click on “ip2location” in the matomo-settings, i’m getting following error/report:
A fatal error occurred
The following error just broke Matomo (v3.9.1):
in […]/plugins/IP2Location/API.php line 56
Troubleshooting
Follow these steps to solve the issue or report it to the team:
If you have just updated Matomo to the latest version, please try to restart your web server. This will clear the PHP opcache which may solve the problem.
If this is the first time you see this error, please try refresh the page.
If this error continues to happen, we appreciate if you send the error report to the Matomo team.
@Paul_Dvorak, I’d recommend you to upgrade PHP soon as PHP<7.1 isn’t supported by the PHP team any more and Matomo 4 will drop support for those version.
Hello I get this warning when I go to System\IP2Location page in Matomo
WARNING: C:\WebApps\Matomo\plugins\IP2Location\LocationProvider\IP2Location.php(94): Notice - Trying to access array offset on value of type bool - Matomo 3.13.2 -
Using php 7.4.1
