Ip address blocked after opening matomo ERR_CONNECTION_TIMED_OUT
when I am using matomo my ip address is blocked by the server.
Google Chrome shows ERR_CONNECTION_TIMED_OUT .
It happens, when I open this urls (examples):
  • ?module=PrivacyManager&action=privacySettings&idSite=1&period=day&date=yesterday
  • ?module=CoreHome&action=index&idSite=1&period=day&date=yesterday
  • ?module=CoreAdminHome&action=home&idSite=1&period=day&date=yesterday
My webhoster could not find a reason and I am using the latest version of matomo.
Any ideas why this is happening?
Thanks for your help.
Jan
EDIT:
My webhoster says the first url blocked with 403 was “/lang/en.json”.
Maybe this information helps.
A few minutes ago I was just opening and collapsing menu items and suddenly the page jumped to an ERR_CONNECTION_TIMED_OUT error by Google Chrome.
Are there ajax calls running in the background?
Are you banned from your host?
If so, then the solution is there:
→ in the config file, in [General] section, put:
disable_http_diagnostics = true
Hi @heurteph-ei ,
thank you for your answer!
This did not help, I am still blocked by the apache server. :-/
Do you have another idea?
Thanks, Jan
Hi @krugmedien
Could you have a check in your Matomo error log file?
Hi @heurteph-ei ,
access_log
https://pastebin.com/raw/JnCwyT8x
error_log
https://pastebin.com/raw/iSAYK4PS
There are a lot of request at the same seconds.
My guess is, that I am blocked, because “I” (matomo) make too many requests. (?)
Do this logs help?
Thanks for your time.
Jan
Do you have several tabs opened at the same time on Matomo?
Can you check on your browser network tab how many request are made in some kind of timeframe (minute). Ask your provider what is the connection limit (parallel HTTP request).
Or do you share the same IP (eg. from company network, the IP is the same from the point of view of the Internet) with other people who access Matomo at the same time?
@heurteph-ei thanks for your help.
Only 1 tab. This time I logged in, clicked on the settings icon, I was blocked.
opended dashboard + settings page. result = 104 reqests in 30 seconds.
(details: https://sync.luckycloud.de/f/849ae6592ed1420f887c/ )
Is this normal for matomo?
I am the only one and using a private internet connection.
Waiting for an response, I’ll update shortly.
In my case, when I open the dashboard, I only send 57 requests…
Maybe you could reduce the number of displayed widgets in the dashboard?
Also, can you past the system check (at least where there are some warnings or errors…)?
(Note: sorry, for security, I can’t access https://sync.luckycloud.de/ or https://pastebin.com/)
@heurteph-ei Thank you very much Philippe for your help!
The solution is to add this line to the config file:
enable_required_directories_diagnostic = 0
Now Matomo is working.
Thanks again and have a great day!
Jan
The error ERR_CONNECTION_TIMED_OUT does not indicate a dangerous problem or an infected file that can harm your system. Instead, it denotes that the system could not connect successfully with the target server. The error in question can also originate due to issues on the server side, mainly if the website is experiencing high traffic or resource constraints, which is mostly the case with shared hosting platforms. There are many reasons for the error to be occured which are as follows:-
  1. Invalid URL
  2. Slow Internet connection
  3. Firewall settings
  4. Server delay or error
You can understand properly in detail regarding the error solution as there are many ways to fix it. I found the helpful article at Certera. com
