I am trying to install piwik to www.myecservice.com but every time I run the install it get errors. Always the same errors and I have tried to install several times. Each time deleting all files and folders including the piwik folder on the root directory then navigating to www.myecservice.com/piwik The errors are as follows:
Invalid argument supplied for foreach()
in ‘/mnt/glusterfs/apache/hosting-dir/25240/38358/piwik/core/Config.php’ at the line 248
#0 Piwik_ErrorHandler(2, Invalid argument supplied for foreach(), /mnt/glusterfs/apache/hosting-dir/25240/38358/piwik/core/Config.php, 248, Array ([allSections] => Array ())) called at [/mnt/glusterfs/apache/hosting-dir/25240/38358/piwik/core/Config.php:248] #1 Piwik_Config->cacheConfigArray() called at [/mnt/glusterfs/apache/hosting-dir/25240/38358/piwik/core/Config.php:292] #2 Piwik_Config->__get(Plugins) called at [/mnt/glusterfs/apache/hosting-dir/25240/38358/piwik/core/FrontController.php:209] #3 Piwik_FrontController->init() called at [/mnt/glusterfs/apache/hosting-dir/25240/38358/piwik/index.php:103]
EDIT
just deleted all files and tried to install piwik 0.4.5
SAME results
ANY help is greatly appreciated
Is there a workaround for this? I am currently using phpmyvisites but it only gives me country level locating. we are a regional company and really need to get location information down to the city level. I have yet to figure out how to get phpmyvisites to do this. Another option would be if I could figure how phpmyvisites is storing the ip addresses in the database I can use another script to work out the city information based on the ip. But it doesn’t seem to store IP addresses in a normal format.
Thank you for your help so far. Any further help is GREATLY appreciated.
A workaround does not currently exist. I’m not even sure what the performance impact would be for a pure-PHP version of parse_ini_file vs the built-in function, especially when parse_ini_file() is also used by the tracker.
Ok. There is a workaround but the code is being held hostage…
Some quick factoids:
The pure PHP implementation is 1/3 the speed of the built-in function (56 ms vs 18 ms) – that includes I/O – and has a bigger memory footprint (62K vs 13K). This would obviously have an impact on tracker performance. (All measurements are approximate and may vary depending on your PHP version.)
