Hello to everyone,
I just have installed Piwik in a LAN server.
The server where piwik is installed has the ip 192.168.1.200, my computer IP is 192.168.1.57
When I try to login from my PC I get just an black page, when I access Piwik from the browser on the server everything looks okay.
Somehow I managed to fix this problem. It was a coincidence that I made a View Page source and read this text, even it was to visible on the browser. This may be a little bug. An interesting thing is that I and my colegues are using the application form Albania and Piwik says that the visitors are from USA. It looks strage to me!
Click here to access Piwik safely and remove this warning. You may also want to contact your Piwik administrator and notify them about this issue (click here to email).
How do I fix this problem and how do I login again? The Piwik Super User can manually edit the file piwik/config/config.ini.php
and add the following lines:
[General]trusted_hosts[] = "192.168.1.200"
After making the change, you will be able to login again.
You may also disable this security feature (not recommended). To do so edit config/config.ini.php and add:
Do you know where piwik/config/config.ini.php is located at? I installed Matomo using Docker and have the same issue as you. It is the last step before I can access the dashboard. I installed Matomo on my Mac.
