Hi!
I love the new feature internal search and it works like charme with standard search parameters like “q”.
But i got one installation where the parameter is tx_solr[q] and the search is not logged. See http://www.bitmotion.de/en/home.html to try it.
Someone got a suggestion what i can do?
Thanks a lot,
Thomas
peterbo
(Peterbo)
2
Did you add that param to the list of params, piwik should log as search keyword? You can configure this in the settings -> websites section.
matthieu
(Matthieu Aubry)
3
It’s possible that this “strange” array paramtere is not working. If so, please create a bug on dev,piwik.org
Alternatively, you can use the Javascript tracking: http://piwik.org/docs/javascript-tracking/#toc-tracking-internal-search-keywords-categories-and-no-result-search-keywords
