If I install the User Flow plugin, do you know if it will take into account the old interactions within the site or will I lose them? So, for example, if a select a period of time that goes back before the installation date of the plugin, will I still be able to see which pages interacted with each other?
Hi @tbaciu
If you still have the raw data of previous trackings, then you’ll be able to invalidate past data and then the next time data will be archived, the user flow will be generated…
