I have installed Matomo on a subdomain - stats.theinternetacademy.nl. This works fine. I needed a second instance of Matomo for another site, so I thought I install this on stats.theinternetacademy.nl/books. But now the first instance gives me a warning that it discovers files that shouldn’t be there, the files under ‘books’ …
I assume it is not possible what I did. Is in possible to install 2 instances of Piwik on the same domain?
You could also use virtualhosts to place the second site under stats.theinternetacademy.nl/books, where the actual folder was /var/www/matomo2. That way the first piwik install wouldn’t know about the second.
