Installed without issues, but zero visits & no data
Hi!
* I went through FAQ/Help and could not find really anything usefull. Checked js code and all other things I know, but still nothing. Please, I need your help.
Intro:
I am using OWA & Google Analytics on a website, and decided to give Piwik a try, since with OWA I have an issue with page titles (none), and GA does not have some features such as detailed visitor reporting like OWA and Piwik.
Problem description:
I am using free hosting at byethost.com and Piwik installation went without major issues (check System Check scrshot below). Only issue was with database adapter settings, I had to switch to MYSQLI instead of default/suggested setting (there was a permition issue for table creation and modifications). Now everything is fine, using phpMyAdmin databese and tables are there, but empty so far.
I have made several visits on purpose but Piwik did not register any of it. Any ideas what is wrong?
Screenshots:
http://imageshack.us/a/img836/9464/piwiksyscheck.png
http://imageshack.us/a/img198/1315/piwikjscode.png
http://imageshack.us/a/img855/7175/piwikphpmyadmin.png
Check if your browser has Do-Not-Track enabled -> Disable it.
Check if you set the “ignore cookie” under Settings -> Unset it.
[quote=“Fabian Becker”]
Check if your browser has Do-Not-Track enabled -> Disable it.[/quote]
I was “sure” this wasn’t the issue, but now when I re-checked this option was indeed turned-on. Reminder to myself: always double-check and don’t assume anything for “sure” :slight_smile:
I couldn’t find this option under Piwik > Settings ?
Thank you Fabian, it works!
Darko
