Somewhere around line 1350 of 0.4.5’s core/Piwik.php, there’s a call to escapeshellcmd(). Just remove that line (or comment it out as in the example given).
Hi there,
I just downloaded and tried to isntall piwik 1.5.1 (newest version to date) and am getting the same error:
Piwik requires either the mysqli extension or both the PDO and pdo_mysql extensions.
On a Windows server you can add the following lines to your php.ini:
I think both mysqli and pdo_mysql extensions are installed already.
Under my C:\PHP\ext folder there are two files named php_mysqli.dll and php_pdo_mysql.dll. Do I have to do anything else to “install” these other then checking off the extensions during the PHP install process?
Piwik is installed on my F: drive and PHP is installed on my C: but that shouldn’t matter… :S
Hi all:
I tried to install piwik 1.6 on my server, but it cann’t pass the second step system check.There was not any error information but only a blank page.
Can any one tell me what the problem and how can I fix the problem.
Thanks a lot.
Hi there,
I just downloaded and tried to isntall piwik 1.9.2 (newest version to date) and am getting the same error:
