Hi!
My second Piwik installation (switched to analytics some years ago and thought I give the 2.x version a try because it looks very promising)…
After installing Piwik following the documentation it was not able to find the database when I went to whatever/index.php. Not really a surprise, because there is no step to define it
Found a config file (config/global.ini-pho) and set the data to connect to the MySql server (database checked from the piwik server - working, user can create tables, …).
Now it can find the database, but I get a
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'piwik.option' doesn't exist
error. So - how can I populate the database? As I created it before going to my site/index.php it is empty
any help is greatly appreciated…
Kind regards, Anton
